Rick - Do you have one of these?
  • Rick - Do you have one of these?
    Item number: 280356156708
    Paste this into Ebay.com.au
    I know you collect drain cleaners!
    Re: Rick - Do you have one of these?
    I just checked,you only paste in the numbers!
      Electric Eel Water Jetter Drain Cleaning Plumbers Tool
      I got these when i searched the item number that you posted
      http://cgi.ebay.com.au/ws/eBayISAPI....fvi%3D1&_rdc=1
      That looks like the K1000 Rodder Machine
      http://www.ridgid.com/Tools/K1000-Rodder/
      RIDGID also have jetters....just follow the link below.
      http://www.ridgid.com/Tools/Jetters/EN/index.htm
        Thats the Model C http://www.electriceel.com/pdfs/salesmodelc.pdf
        I really need to get me a new digital camera, I post some pics of interesting drain machines.
          this is what i have. a general model #82 / 88. same as the electric eel that's on ebay.
          http://www.drainbrain.com/pro/propdf/mod88.pdf.
          take a close look at the bottom of the model 88 page link. the no wrench coupler for type "g" cable. that's the adapter i use for my timberwolf drill. comes in either a 1/2'' or 5/8'' drive shaft connection.
          the ebay eel is in very rough condition and they don't even know what they have. they're calling it a jetter
          here's the picture from ebay
          don't worry ridgid. i also have a 1500
            Here I was being a "smart arse" but you all knew what it was,who made it and how old it was!
            Cheers
            Graeme
              1440 rpm
              read the metal tag. that puppy runs at 1440 rpm. us model 500 rpm. breid
                Re: 1440 rpm
                most likely that's the motor rpm's prior to the gear box reducer.
                i can't picture any cable spinning at 1440 rpm's.
                  me neither. it would kill someone. my first thought was that it would pull the machine in the pipe or try. lol.
                    I am willing to bet Rick does not have one of these.
                      i do have the #426 channelocks pictured with your snake
                      a #430 and 426 are the best of the best
                      was that an old spartan or burton i know i've seen it before.
                        Spartan 600. Here is a close up pic of the motor plate and the drum plate. Also here is a drill that After it nearly beat me to death I do not use any longer. Instead of a trigger it has a push switch and stays on till you push the switch back the other direction to turn it off.
                          I am thinking of setting up this drill, like you guys have to spin the 1 1/4" cable.
                            i wouldn't
                            all metal d handle drill will either break you or kill you
                            a right angle timberwolf works better than a hole hawg or d handle.
                            the right angle rest very comvortable against your leg, hip or ribs.
                            remember you typically need 1 hand on a cable and that drill is a 2 hander plus you don't want all that old heavy metal.
                              Ah thanks for the advice. and that one is weak compared to the first one posted. But the first one doesn't have a trigger switch.
                              I am working on getting my vid cam up and running so I can make a vid for you guys on how that old spartan 600 works. It does really well, just has a learning curve. I used that thing for a few years, and one of the clips that hold the two halfs of the drum broke, so I shelved it and put my 100 back on the truck. But after seeing the old Model C there made me want to dig it out and fix it up again.
