tub drain clearing
  • tub drain clearing
    I manage a small apartment building and am looking for a better tool for clearing sinks and tubs. I bought the auto-spin two years ago, cleared a few drains with it (took a while), but now the cable dosent seem to want to advance more than a few feet. I keep hearing that the k-39 is a better choice, but i'm wondering if i should just move up to a larger machine, like the k-400. who has an opinion to share?
    also, has anyone seen the auto-spin exhibit behavior like above (not advancing the cable so well?)
    Re: tub drain clearing
    auto spin was never meant as a commercial unit. either the feed bearings are shot or the cable is a rusty twisted mess.
    remove the cable and see what it looks like.
    the k-39 is a great machine for tub drains. use the standard 5/16'' cable and bulb head auger. remove the overflow trip lever assembly and linkage with plunger. go slow until you're through the trap.
    the 400 is not a practical machine for tubs as it's cable is too big and stiff for a 1.5'' waste and overflow. you'll wipe out your tub and damage your cable.
      Depends on type of bathtub traps you're dealing with...
      P-traps: 1/4 inch or 5/16 cable machine
      Drum trap: General Kinetic Water Ram
      Either can also be used on lavatories.
      Kitchen sink needs larger cable, no Ram.
        Your cable is twisted in the drum.The K39af is a perfect choice.
          Wait a minute Rick, K-39? Surely there is some reason a K-60 would be better.
          I like a sits-in-the-tub-on-a-towel 1/4" cable machine, like this
          http://www.gorlitz.com/index.php?act=viewDoc&docId=5
          because I like to have both hands free instead of having one occupied holding the machine in the air.
            I prefer the K-50 with a 5/16" canister.
              I too like the K-50 with the canister drum.
                I like to hire plumbers that have several options and that do this every day for a living. It cost less then having to replace a damaged machine, tub or sink. In the long run a good service agreement with a local plumber should do the trick. Usually if you have one plumber doing your work with a contract some will provide discounts.
