Electric eel cable for a ridgid K-1500
  • Electric eel cable for a ridgid K-1500
    Can you use Electric Eel cable on a Ridgid K1500 ?
    Re: Electric eel cable for a ridgid K-1500
    Yes you can! It works Awesome!
      Thanks I also purchaced a bunch of ridgid K1500 heads I need to make an adaptor to go from K1500 heads to electric Eeel cable .
        you can probably just salvage the blades and use the holder from the eel. that way you don't end up with an adapter that's too long for the bend.
        or see if the ridgid male end will couple with an eel cable and have your front cable the adapter. only issue is that the innercore will not connect to a different front coupler.
        i use the general g connector cables and just use the ridgid blades and others.
