How do you pull the cable out on a sectional machine ?
  • How do you pull the cable out on a sectional machine ?
    I was wondering if there was an easier way to pull the cable out. When I have done main line stoppages from a roof vent. I ask the customer to run water in the bath tub after I have cleared the stoppage to clean the line and my cable than I pull it out of the drain. If the cable is difficult to pull out I run my K60 and pull out a little at a time. Sometime it hard on the back. I bought an Electric Eel on E-bay I am hoping that this unscrews the cable out of the drain. David
    Re: How do you pull the cable out on a sectional machine ?
    push in - pull out
    kinda like the karate kid
    steve
      While spinning the cable in the forward direction push the cable on the edge of the pipe/cleanout and it will "screw" it self out of the drain.
        thats to much work! I`d just leave it in there for next time.
        Get a drum machine and let it do all the work for ya
          He chases tornados you do the math lol
          Seattle Drain Service
            That depends on the direction of the wind on the cable.
            With my cable pushing on the edge of the cleanout/pipe forces the cable in.
              Are you serious??? Ever hear of the reverse button? The cables comes out easily and quickly.
                Well if your cable is wound different than the Ridgid cable, then run it on reverse, and push it on the edge of the pipe, it will screw itself out.
                  I use the reverse button to get me out of a blockage.
                    Thanks next time I will try this method.
                      You should be running the K-60 in forward whether putting it in or pulling it out. I seldom try to pull the cable out all at once - I pull it the same way I put it in - by raising up on the cable while the handle is down, the releasing the handle while letting it slide through the machine. It takes a little more oomph from a roof vent and you might have to just manually pull it while the machine isn't running to get it lifted up.
                      Reverse is just to unstick it, and Ridgid's instructions say to use it sparingly.
                        So you got a k60-7/8 cable and want to use it with an electric eel-1 1/4 cable? Hope you got a J conector
                          When I rod with my K-500, K-1500, and even my old school K-60 , on long runs I feed the cable in on reverse, since it does self feed itself nicely. Then when I retrieve the cable I run it on forward holding it on the edge of the pipe/ clean out so it can self feed out of the line. Sectional machines do not make a huge difference which direction you run them in compared to a drum machine.
                            reverse actually pulls the cable in on the c-10 k-60 cable.
                            but honestly i have never had an issue running my reverse auger in reverse to clear stoppages.
                            it's actually the secret weapon i talk about.
                            run the cable as need to free it up and pull as it frees up. it might need to be powered all the way or just a few sections.
                            weight, gravity and fittings dictate what kind of resistance you have.
                            ps. for all you drum guys, please post photos of your drum on a pitched roof through a 2'' -4'' vent pipe cleaning a main line stoppage.
                            you all have seen plenty of mine. lets see yours
                              Your saying it pulls it in as into the pipe? If so that is what I been saying, Reverse feeds cable into the pipe forward pulls it out.
