question on electric eel L connections
    Re: question on electric eel L connections
    that is just like the one I got the other day , it was a less costly one just to see if I liked the style , I think I will. I was not sure if it would be strong enough because of the amps "only 7.5 " but I have seen some of your pics and I bet it will work just fine.
      Edith will turn at-least 180' of 1.25 inner core. She's a bit sluggish with that much cable, but she always gets the job done (3 yrs now)
        We use a milwaukee right angle hole hog to run the cables. Our first drill lasted three years.
          I bought the Hitachi D13. The shaft I ordered from E eel did not come attached to the L connector adapter. Looks like I have to drive a pin through the shaft an adpapter (there is a hole that lines up) I was thinking of bringing the shaft and adapter to a machine shop and having it welded on but then it probably would be out of round when it spins? Or maybe it wouldn't matter?
          what do you guys think?
          Thx,
          Harvey
            Use a roll pin to secure the connection. What did you pay for the shaft?
              I believe I paid 12 bucks for the shaft. And BTW- after looking inthe bag I did find two roll pins for securing the adapter to the shaft. I guess they give you an extra as only one is needed.
              I think the electrici eel parts were sc-10 and sc-12 shaft and adapter.
              thx,
              harvey
                ..Man ! that setup still scares the crap outta me . I think I will stick to my machines ..I would like to see one in action though
                • #23
                  The drill set up is great been using it for 12 years will lay some whoop azz on roots and hard blockages.
                  You like my lousy cell phone pictures? My contract ends in December the best time to get a new cell phone One that takes better pictures and has flash
                  Rod
                  http://unclognh.com
