Flushing water lines
  • Flushing water lines
    After rodding out a drain or even plunging it, is it best to flush the lines with cold water or hot water? I can see the benefits of each but was wondering what works best from your experience. Thanks!!
    Re: Flushing water lines
    cold for sure. cold will keep it from sticking and is plentiful. hot is very limited in volume.
      I always try and run as much water (Cold) as possible after I unclog a drain, doesnt matter what drain lateral, sink, tub ,whateve rit is, I want to be sure its not going to back up when im 3 blocks down the road. plus the customer feels better when they can visually see theyre drain is working
