Ridgid Cutter
  • Ridgid Cutter
    Looking to get a cheap retriever for 1 1/4" ridgid sectional cable. There are three available for $15.- each on E-Bay. David
    Re: Ridgid Cutter
    those are actually more geared for the 5/16'' sectional rodders. saw them last night
      Re: Ridgid Cutter
      Yes, but it does have an adapter for the 1 1/4" ridgid style sectional cable ? David
        Re: Ridgid Cutter
        Sorry to thread steal but I need a 1 1/4 to 7/8 sectional adapter I want to try the larger cutter heads on my 7/8 k-60
        Seattle Drain Service
          Re: Ridgid Cutter
          yes it will fit a 1.25'' cable as it has the same end. but good luck trying to get it to go around a 90.
          the cutter is designed for straight runs through manholes with a k-1000 rodder.
            Re: Ridgid Cutter
            it's easier to just swap the blades into the 7/8'' tool holders.
            making an adapter for 1.25'' to 7/8'' is easy, but it will create a longer non flexible front coupling.
            the blades will fit the tool holders as i do it myself too
              Re: Ridgid Cutter
              Thanks Rick, I haven't been on this site for long, I really appreciate your knowledge and opinions on this site. David
                Re: Ridgid Cutter
                I'll just retract my bid since everyone and their mom knows about the cutter.
                  Re: Ridgid Cutter
                  ben go ahead and buy them. you can use them as a paper weight or book ends
                    Re: Ridgid Cutter
                    Welcome to the internet. Can't put it back in the bottle!
