¾” IC question?
  • ¾” IC question?
    ¾” IC question?
    Has anyone ever had a C-100 cable pretzel up in a 4”-6" pipe? clay
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: ¾” IC question?
    Originally posted by appletondrain View Post
    ¾” IC question?
    The larger the pipe, and the larger the cutter you are running, the cable can turn around on itself. I have had it happen a few times. The smaller cutters it is less likely to happen. Which is one of the reasons when I clean a sewer I use a starting cutter like a small 2" or a straight auger or the Ell springy spear head. Once I get that through then I go to a 3" then 4" and finally run a 6" cutter though.
    Oh a note if your cable is real limber it can turn around easily on it self as well.
