Bamm!!!
  • Bamm!!!
    http://www.youtube.com/watch?v=OM9S1w9TbJc
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/OM9S1w9TbJc...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/OM9S1w9TbJc&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    Love the P trap BAMM
    Loving the crap products they come up with.
    BAMM it shot up the other side of a double bay sink all over my ceiling
    BAMM I got toilet water in the eyes and mouth
    BAMM Black crud shot out of the over flow.
    Bet that blue water had soap
    BAMM I hate when that happens
    Rod
    http://unclognh.com
    Re: Bamm!!!
    That's actually not a bad tool,
    There are many people in my area, that cannot afford $125 for a service call when there sink backs up ( Many seniors etc on fixed incomes)
    If my Grandma was still alive, I would get one for her.
    Seems it's priced right as well.
    Then again, I guess I could have bought my Granny a k-60
      Re: Bamm!!!
      Also,
      Its just a smaller version of the:
      Kinetic water ram by General
      http://www.drainbrain.com/pro/waterram.html
        skool
        i would do my grandmoms for free. but of course not yours. breid...........
          Re: Bamm!!!
          Makes you wonder why they dont fill the sink up like i see when i get the call
          could work on the lav ,if you have a third hand to stop up the over flow
          that would be a suprise, if it didnt move
            Re: Bamm!!!
            Notice they only used it in a stand up shower not in a normal tub & shower. Because they know it will shoot out the over flow and trip waste.
            HO does not know to take out the trip waste and block it with a rag and close the sink and block that over flow to. With even doing that you still can't blast away.
            Love to see a HO rent or buy a real air ram
            Just a few more pumps may do the trick BAMM!!!!!
            Rod
            http://unclognh.com
              Re: Bamm!!!
              i had the kenitic water ram at one time and i could never make it work properly. so it sat in the van forever. what if any are there any secrets to using it. besides keeping your mouth closed!
              the only dumb question is the one that is not asked!
                Re: Bamm!!!
                Will only use it in drum traps and coffee bean drain lines
                Is the clog before the vent or after the vent? Don't blast away increase pressure make sure all over flows are blocked. Make sure it can't pop up some where else.
                I may only use it 5-10 times a year. NEVER use it in toilets and urinals if you do your asking for trouble. Air ram does work under the rite conditions
                Rod
                http://unclognh.com
                  Re: Bamm!!!
                  http://www.preparedness.com/homowsup.html
                  This is one homeowner tool I've actually found useful... silly crappy plastic tube that hooks on a faucet with a crap 'nozzle' on the end. Good for frozen tub traps. It's embarrassing to use if anyone is watching but it is the quickest thing for them.
                    Re: Bamm!!!
                    I like the ghetto "trap" they had under the lav sink in the video. It was like something someone rigged up out of radiator hose, only clear. What a joke. I doubt it would even hold enough water to keep sewer gas out, lol.
