Pluuuuged drain
    Re: Pluuuuged drain
    I wonder why i never need a camera to clean a drain..
      Re: Pluuuuged drain
      Electric Ell made a drop head attachment (SC-19) that you can attach a standard cutter to. I have had some good luck with it when it comes to the drop down pipe into the trap. Some of them are Tee's with a clean out plug on the top of the tee. Lots of time it gets buried, and what can be happening is the rodder is turning upward and hitting the clean out cap instead of making the turn downward.
        Re: Pluuuuged drain
        in situations like this I have straight cables / no head that I have had luck with, usually rust. If I'm reading right it seems as though this drain is under concrete and sounds like rust/scale or an object as twice pipes said. Is there anyway to put a canvas blowbag on it ? I have also used small cable to get through a 3" scale filled trap just to get the water flowing and then jetted.
