Pluuuuged drain
  • Pluuuuged drain
    I have a 4" drain in a grocery store, it appears to go into an old trap or a downward 90 and leg is plugged. I have a feeling the pipe/fitting has separated. The k60 with either size cable and the k1500 will not get past the 90. I can see with the camera a 90 with water at the bottom of the 90 but cannnot get around it. I can try jetting but am nervous that if the pipe is separated the jetter will find its way through the joint. Any suggestions.
    Re: Pluuuuged drain
    Put a spiral blade on there and "pop" the feed handle in while holding firm pressure down on the cable. Put a bend in the end of the cable to make things easier.
      Re: Pluuuuged drain
      do you have a smaller camera? if it's full size it might be hanging up.
      the only dumb question is the one that is not asked!
        Re: Pluuuuged drain
        Can't get 5/8" through a 4" 90? Sounds like some bad ju ju man.
          Re: Pluuuuged drain
          Originally posted by jcsplumbing View Post
          can't get 5/8" through a 4" 90? Sounds like some bad ju ju man.
          J.c.
          Ahh...Si`
            Re: Pluuuuged drain
            I have tried almost every style of head for the augers. The camera head gets caught up, but the 5/8" cable won't go through, a smaller camera also won't go through.
              Re: Pluuuuged drain
              This happens to me when they use what I call a doughnut gasket. The lateral will be 6'' and then a 4" pipe is stuck inside with a doughnut gasket. Those gasket let so many roots through and they get so big because they push the gasket out of the way. Of course it could be a seperated pipe.
                Re: Pluuuuged drain
                how far away to the water? possible to wet vac it out so you can see what's up with camera?
                  Re: Pluuuuged drain
                  you beat me to the punch
                  suck out as much water and see what the camera shows.
                  time to get that microdrain were all raving about
                    Re: Pluuuuged drain
                    The blockage is 33' from the clean out. Is that too far?
                      Re: Pluuuuged drain
                      I would try my older closet auger with the end bent out,
                      To try to clear the trap out, so i could use my cable..
                        Re: Pluuuuged drain
                        How close to the outside wall is the area you can not pass?
                          Re: Pluuuuged drain
                          Maybe its an old drum trap.
                            Re: Pluuuuged drain
                            We use a septic truck when all else fails. Sometimes you can suck the line open. A Shop Vac will have a hard time removing 33 feet of standing water from 4 inch. What the worst thing that can happen if you jet it. Even if you get out of the pipe most time you can tell. PS I have had to dig up a drive thur at the local Taco Bell with a 580 to remove my chain nozzle from a broken pipe were there was a test ball that was used as a clean out cover by the drain guy before me. How deep is it can you locate it with out seeing it?
                              Re: Pluuuuged drain
                              Unless there are signs of mud/soil on your cable, I wouldn't assume it's broken or even separated. Surprised our resident pros haven't mentioned this. It's probably just heavy scale/rust build up or possibly a lodged object.
                              As mentioned the line needs to be evacuated to get a visual.
