More jetter questions...
  • More jetter questions...
    Since my jetter is a converted P/W, it has no gauges. Where do you get them and where do you instal them? Pics would be great. Do they just have a psi gauge? Or is there such a thing as a gpm gague?
    Thanks in advance!
    www.ClinkscalesSeptic.com
    Re: More jetter questions...
    we just use an oil filled psi gauge screwed into a tee on the outlet of the pressure washer.
      the pressure gauge is a simple add on feature. water cannon has a simple quick connect snap coupler with a gauge built in. $12 and you're set to go. just install it on the outlet hose connection coming off the pump.
      as far as a flow meter. no real need for it as it's just for test purposes. plus it runs about $300.
        Thanks!
