Sectional Coupling
  • Sectional Coupling
    Do they make a 7/8"x5/8" coupling to connect the different sizes if one wanted too?
    Thanks.
    Re: Sectional Coupling
    I have seen a 7/8" by 1 1/4" coupling in the past, but never really seen one to go from 7/8" to 5/8" but who knows maybe they made one.
      Thanks.
      As Shaquille O'neil would say...
      WUT?
      If you're running that through a powerfeed that would cause problems.
        WUT?
        HUH?
        A sectional machine does not have a power feed.
          i made an adapter for my 7/8'' to run the 1.25'' cutters. pretty simple with a lathe.
          problem when going from 7/8 to 5/8'' is the cable torque thresholds would be way off.
          5/8'' sectional is way weaker than the 7/8''. unless you run the extra heavy 5/8'' c-9.
          rick
