Jetting?
  • Jetting?
    Would it work if i put a jetter nozzle on my pressure washer hose?
    Re: Jetting?
    There is a conversion kit available to turn a pressure washer into a jetter. It sold for around $150.00
      Re: Jetting?
      Yes you could put a tip on the hose but it is not slippery like a jetter hose and probably wouldn't go very far.
      Seattle Drain Service
        Re: Jetting?
        I have seen in the pressure washer accessory section of my truck parts dealer an assortment of nozzles for pressure washers to use as a jetter. As long as it is sized right for pressure and flow it will work. They even have a rotary nozzle.
          Re: Jetting?
          dan, list your specs and we can size it.
          the hose is a factor for distance and tight turns, but for straight runs it's not an issue.
          list your specs and your possible job conditions and we'll see if it's possible.
