K-400 augers function
  • K-400 augers function
    Hey folks, I just posted this on the expert forum but i'll ask here too. I am a facilities manager and have a Rigid K-400 drain cleaner. I was looking on line for info on what each accessory auger for the k-400 does. Some are obvious, but others not so much. I would just like a quick explanation of each augers function. I was on Ridgid's site but couldn't fine anything. Thanks for your time. Dave
    Re: K-400 augers function
    Check here. Click the first link beside drain maintenance. It will be an Adobe pdf. file. It should download and open.
    Some explanations on page 9.
    http://www.ridgid.com/Tools/Product-...s/EN/index.htm
    Good Luck.
      Thanks J.C. That's somewhat helpful. Dave
        Could this be a case of "If ya gotta ask"
        There are so many heads that a detailed explanation would run a bit long...
        K-400: Get a drop head bulb for it and stay away from everything but soft stoppages.
        Bill
          Thanks Bill, I was wondering about that drop head. I'll get one. On Toolup.com they have 5 different straigt bits at different prices. Whats the difference?
            Different straight augers are different sizes for different machines & cables.
            So if you had this machine with this cable:
            http://www.toolup.com/ridgid/26993.html
            Then you would want this straight auger:
            http://www.toolup.com/ridgid/62990.html
            I think this is right. I'm not an expert drainperson.
