Winterizing small electric jetter
  • Winterizing small electric jetter
    what does everybody else do to winterize small electric jetters ???
    I woke up yesterday morning to snow on the mountain tops, and realized winter is here, and i never had to worry about winterizing my small eelectric jetter before, Just wondering what works best ?
    Re: Winterizing small electric jetter
    I put a washing machine hose into a jug of -30 windshield washer fluid then run the pump till it comes out of the hose. Never had a freeze up.
      RV outlets have trap anti freeze, safe
        we use RV antifreeze, dump a jug into the holding tank on our big gas jetter, then run it until it hits the end of the jetter hose.
          what Ron said.
          or, if this works for your set up, I keep an old 90wt jug (cause they have the nice nozzle tips which fit mine's inlet perfect) with blue water in it and squeeze til it runs blue.
          or, actually, that's what I did before I had my beloved heated indoor parking.
          rv anti-freeze=$6/gallon, window washer=$1.39/gallon, and the dogs don't like it.
            move to southern california .
            right ben
              What a Great Idea rick!!!
                I think I would actually miss a real winter. That and frozen piping in older homes is good business for some of us. I really want a propress too for working in those conditions, but I think it's more likely that i'll buy myself a jetsweat kit this winter.
                  Put the Jetter, on a jet to Florida, for the winter
                    I run antifreeze through mine gets dam cold up here -50 or more
                    Helps lube the pump too.
                    Rod
                    http://unclognh.com
                      Know what You mean. Had a cold snap here last winter. Got down to 65 F for a whole day!
                      Of course People were chasing Me around with hatchets,the same day! This is Calif.
