So I bought the Ridgid Auto Spin and.....
  • So I bought the Ridgid Auto Spin and.....
    I've been eye balling this thing for a couple of years now. Held off because of what others have said here. I usually listen to what you guys preach but not this time. Ok, it's a Harry Homeowner special but I really like the design. Ridgid could have done a little more with quality it to make it a pros tool also.
    I bought a used one but it likely never worked out of the box, and once purchased, you can't return them to the store (at least that what it says on the box) I got it so cheap that it should pay for itself after 2 uses. The motor would run but the cable would slip with the slightest of tension. I've seen this complaint several times from others. Disassembled, tightened clutch, and reassembled in 5 minutes. All good.
    Really wasn't looking to spend $300+ for the K-39AF just to clear the few tub and lavy stoppages I come across. Thought about buying another drum adapter like I had for my K-60 but thats really overkill.
    Pros
    All plastic coating, so no scuffing up the sinks or tubs
    One handed operation with the air acuated foot switch
    2 way Auto feed
    Decent torque @ 400 rpms
    No mess with a guide hose
    Cons
    Stock 1/4" cable a little flimsy
    I prefer a closed bulb rather than an open retriever tip
    Auto Feed feels a little sloppy, looks the same as K-39 but haven't compaired them side by side.
    Only does up to 1-1/2" pipe. Still need the 5/8" cable for 2" shower drains
    Looks like it came out of a 5 year olds toy box
    Re: So I bought the Ridgid Auto Spin and.....
    Here is the pro version of the auto spin. http://www.ridgid.com/Tools/K40-Sink...e/EN/index.htm I got to use this machine I really like it a lot. I too own an auto spin, I was down at the girlfriends place in Lexington KY and her shower was clogged, so I went to the Home Cheapo and bought one of these. I was happy with the results. Only thing is I wish the clutch was a little stiffer and not slip so easily.
      Oh do not try updating the cable with the next size bigger you will bust the anchor clip. I need to some how get my hands on a new iner drum for this thing now.
        HA! I just bought a 5/16" cable but haven't put it in yet
        I was worried if the clip would hold a bigger size, I guess not
        Back to Ferguson on Monday to swap out cables
        thanks for the tip Ron
          I cut the bulb off and spread the cable open a little to catch hair. I cut the cable shorter after every kink then I replace it when it's to short. I just plan on replacing them often. It's a good machine for what I use it for.
            i don't like the k -40 I bought one when they first came out. used it for six month a that was it. its been in my basement for the last fourteen years
            k50 k39 I use them day in day out.
            Monday Just ordered
            3 k-50
            1 k60SP SE
            20 boxes of C-7 & C-8 cable
            1 A-62
            and a lot of cutter's
              Monday Just ordered
              3 k-50
              1 k60SP SE
              1 A-62
              you must have been reading my post my words exactly
              you can't go wrong with your new choice of machines.
              why only 1- k-60
                Maybe, just possibly, that after 14 years, the k40 has been redisigned and is better? Just a wild and crazy thought.
                  why only 1- k-60
                  rick.[/QUOTE]
                  oh don't worry Rick ill get more k-60's as time go's by
                  but i need a vic machine & a power cutter to go with it soon
