Longest Drain Cleaning
  • #46
    Re: Longest Drain Cleaning
    I RAN 380" X 6" CLAY SEWER PIPE WITH OLD SPARTAN 1065 RUNNING ON ONE
    DRIVE BELT, THIS WAS AT A APT. COMPLEX WHERE THERE WERE TWO THREE STORY
    BUILDINGS APPOX. 50' HIGHER GRADE THAT HAD ALL THE SEWAGE FLOWING
    OUT OF THE BUILDING I WAS SNAKING FROM !
    NO CLEAN OUTS HAD TO DIG UP AND EXPOSE SEWER PIPE TO GET ACCESS
    FOR CABLE
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
    • #47
      i had no idea the spartan 1065 could move that much cable?
      • #48
        It depends on the cable. If it is no inner core cable it will have a hard time. But if it is double owund .66 cable it can do it with ease.
        • #49
          Convalescent hospital. Line was about 580' from c/o to the manhole. Ran the entire length of the hospital. Took 2 guys and 4 reels of 180' of cable. I hated it. They were on a 90 day maintenance agreement. Tried to talk them into installing several c/o's but they refused every time. This went on for years. The only good thing was we charged by the foot after 100'.
          • #50
            Don't go much over 100 feet. Did a 300 footer years back.
            Rod
            http://unclognh.com
            • #51
              My personal best was 600' from a Menards store (same as a home depot)
              on the roof with a thunderstorm approaching.Root blockage at 557'.
              Finally found a asphalted over man hole in the road where the sewer tied in and there
              was the root intrusion!
              • #52
                265 FT. with an electric Eel and 11/4" cable from an old church basement under a parking lot to the street. The clay pipe was over 100 years old I hit the stoppage on the last cable I had. But I have had customers insist I rune every cable I have in the van and cuss me out that I don't carry more then 210 ft, even if there drain is only 100 ft but after I explained that it would cost more to run that far and I would be 110 ft in the city line they cant believe I would charge them any extra. I have had them go in my van and pull out every cable I had wanting me to run it down there 75 ft line.
                • #53
                  jay mpls
                  Which machine did you use to go 600'??
                  • #54
                    That would earn them a pipe wrenching. That's My truck. Thy invited me onto their property, but I did Not invite them into mine. My truck contains things that can kill, maim, and poison people, probably the worst of which is the 36" steel wrench by the back door.
