Longest Drain Cleaning
  • Longest Drain Cleaning
    What is the longest drain you cabled? which machine did you use?
    Today a cabled a main 6" clay, 190' with a 1 hp. electric eel. i hit roots at 160' and 175' and it went through it like butter.
    Around here you are required to have a c/o every 100' but some of the really old homes do not have that.
    Re: Longest Drain Cleaning
    165' o'berg
    K1500
      285' of 4" Transite using 2 K-1500's in tandom....never again!
        I rodded a 6" line full of grease 600' with 1ΒΌ" cable with my 2 HP rothenberger R 750
          200' with my General Maxi Rooter 2 100ft cable sections. Went out fine but came back slow had to pull it back by hand first 100ft.
          Seattle Drain Service
            I too cleared a stoppage at around 600' with a Quadra-Plex (1/2 hp) using a 3/4" cable. It was for a Manns Theater and 550' of it was through the parking lot.
            http://www.quadraplexinc.com/machine.html
            The weight of the cable slowed the machine down to where it was really straining. When it hit the stoppage it was a soft stoppage and we had to spin the drum by hand to clear it. I told the Corporation they needed some cleanouts and they decided it was too expensive. Fortunately they never had a problem on the main again and eventually a church bought the building. I would have rather used my KM-1500 or K-500 but I did not have enough 1 1/4 cable.
              Boy do I feel small, the longest I had was tree roots at 92'.
              Do you guys get long cable jobs often?
                I have ran into a total of 4 that are over 200' . Avg around here is 80' to 130'
                  150' with the 1500
                  with the electric eel we get jobs 120' to 240' feet 2 3 time a year
                    It's been 2 years since I've gone over 100 feet
                      240' with a mytana. even with changing drums easily. It is still a pain. Nothing like putting on the 2nd drum only to find you need to change cutting heads to get through the blockage. Around here if you can't go over 100' you are not a drain cleaner. A lot are just over 100' thats why I try to keep 120' on the drum.
                        I keep my 1065 on the truck loaded with the 100' of cable and its 10' anchor. Along with an extra 50' in a cable rand. I also keep a K 1500 on my truck with four rands with five 15' foot sectionals totaling 300'
                          That's a lot of extra weight. What you driving?
                            The long , tall wheel based Sprinter its a 2005, 2500 series. It does not seem to mind the extra weight one bit. Once I clean out the back a bit I will take a couple pictures. The back is a bit of a mess from a tankless heater I installed over the weekend, and been busy since.
                              i carry 75ft. on 1065 and 3 50ft. cables on trk. i got a good bit of sewers 200ft. plus, i like the 50ft. sewers with outside c.o.
