jetting sinks
  • jetting sinks
    what lengh of hose? this of course would be for all in the house traps. i was thinking 50 feet for everyday. but now i'm wondering if i might want to carry a 100 footer just in case.
    the only dumb question is the one that is not asked!
    Re: jetting sinks
    I carry 75 feet of 1/8 " seems to work good.
      Re: jetting sinks
      Same here 75 ft of 1/8. Better to have over 50 for the day's you with you had more.
      Rod
      http://unclognh.com
        Re: jetting sinks
        I use exit flex dp 1.3, which is (nominally) 3/16" id hose. 90% of jobs on internal drains come in at sub 30'. 35' is a magic # for me for 2" lines. I also carry a longer hose in this size, 70' to 100', for the oddball 4000' house with the kitchen all by itself, and for the commecial kitchen where I'm doing 20 floor sinks on pm.
          Re: jetting sinksuse
          I use 50 feet of 1/8. It work most 99% of the time. I do have 100ft of it I use just on frozen water lines.
            what nozzels are you using for sinks and for ice?
