Drum Machines Task Drain Cleaning as Less Work for Operator Page Title Module
  • #31
    Re: Drum Machines Task Drain Cleaning as Less Work for Operator
    dunbar, i'll take you as a man of your word and no lie detector is needed. your way of doing a good job is different than my way of doing a good job, way different.
    I'm jaded, there's no turning back at this point either.
    The "grind" as in dealing with people will reach you eventually and I call it throwing the meat on the skillet and eating it, rather than soaking it in sauce, preparing the side items that add flavor.
    As you see in my post, I still win acceptance for stepping above the level when my competition plays by another set of "expected" rules.
    I'm not the prettiest thing on the planet but I know residential plumbing.
    • #32
      the advantage of the sectional cable is the flexibility of the cable. it's flexible enough to get past tees and yet stiff enough to cut roots.
      not uncommon for me to access 1.5'' drains and clear 4'' lines with my 7/8'' cable.
      drip, have you been ignoring my hundreds of post discussing this
      do some searches and every picture and answer will already be there for you
      Not ignoring, but I'm a "headline reader". If the headline doesn't have sex, violence, or really cool tools, I ignore it.
      I'll call my Ridgid rep next week and get his skinny white butt up here. It's a 3 hour trip for him and I don't buy 1/2 the time.
      (The Low Spark of Steel-Toed Boys)
      • #33
        How do You run 7/8" cable in a 1/2" drain? Never saw a k-60, Myself. Is the cable like a slinkey?
        • #34
          tool, that's 1.5'' drains
          not .5''
          • #35
            not .5''
            Sorry,I meant 1- 1/2"
            • #36
              I`m not gonna say anything
              • #37
                Return of the bucket rider!
                • #38
                  yep
                  • #39
                    Is Dat a seesnake being used with a regular TV??? Do tell Distance counter work also? If so that is total awesomness.
                    Rod
                    http://unclognh.com
                    • #40
                      Yes it is and I also have it set-up to hook to my DVDR that has many deferent formats like MP3 Com/Disk and so on. The TV has VHS built in.
                      I like to make things more user friendly.
                      I`m kind of a R&D guy if you know what I mean
                      Yes, the Distance counter and all works.
                      • #41
                        That's awesome No need for the expensive monitor set up. I think the Rigid monitors are way over priced. Nice set up.
                        The push cable and camera head Ridgid puts out are good.
                        Rod
                        http://unclognh.com
