jetting through roof vents?
  • jetting through roof vents?
    anyone do this?
    if not what are the dangers? flooding?
    the only dumb question is the one that is not asked!
    Re: jetting through roof vents?
    I Jet sink drains from the roof all the time,its easier than dragging a jetter hose into the kitchen if thje sink is full of water i will snake first to unclog, if there is some room for water in the sink i will run my jett with a 3 rear 1 forwrd nozzle out to the clog as fast as i can and once it is draining i will spend time cleaning the line, ivw also jetted laterals through vents using the same method or i have a helper watch the floor drain and let me know if it starts to flood !
      are you using aqua moles?
        i do it, but you better have a person watching what's going on.
        also remember that old school vents might be a vent 90 and not accessible for a jetter hose.
        no hub fittings are no problem. abs, pvc or durhah can have the vent 90's
