Pressure Washer Specs
  • Pressure Washer Specs
    Will these specs work for a jetter and what heads do you recommend? Whathog, RootRanger?
    6.5H.P.
    2500 PSI
    or do I need to go and buy a better pressure washer?
    Re: Pressure Washer Specs
    Sorry those specs are fine for sink drains with special small nozzles. You didn't give GPM specs but I will guess and figure 3 GPM or a little less. But find a 2500-3500 psi usually 11-13hp 4-5 GPM pressure washer and you can do the rootranger for roots it will be slower and not be like the larger units but you can learn and do jetting. Sludge etc are common and you will be able to do them in 3" to 4" lines.
    Seattle Drain Service
      Yeah your on the money there 2.8 to 3.0 gpm, I just got of the phone with a local company that makesunits, they make a unit for Mr Rooter, and they us a 13 h.p 3000psi 4.0 gpm unit.
      after that ,would you go to a trailer unit?
        No go for a skid mount unit usually 24hp motor,8-12 gpm 3000 psi. But I like a little less gpm nowdays say if I had a choice between 8 or 10 gpm i would pick 8 gpm if I got 4000psi instead of 3000
