Dehairing your Cable
  • Dehairing your Cable
    I have to clean my tub and shower drains about every 12 months. I always use a k39 and its always the same gigantic clump of long hair that gets wound up into the cable. Cleaning the drain takes almost no time but getting the hair out of the cable takes forever.
    So how do you guys unspool the hair, roots, string, etc. from you cables?
    Re: Dehairing your Cable
    I use a utility knife, and some cheap baby shampoo soap.
    The shampoo makes it slick. Which untangles the hair. Than I come along and score it off with the razor blade
      I just use a torch to burn it off in the customers basement
      Just kidding!
      I just use a razor knife to score it. Never tried the shampoo trick. I'll have to try it next time, sounds like a good idea.
        channel locks.
          Amen Brother!
          The voice of Ridgid has spoken. Believeth as I have beareth witness, experienced sucheth sameth problemeth.
          Anyone tries to say otherwise is bending the truth!
          Oh what a camera and 20 years ago could make me these days...
            Let it dry, cut it, then use it for floss.
              i usually just pull stuff off by hand, either ripping or unwinding. when its too tough razor knife, or channel locks.
              i recently ran a sewer from a clean out at the rear of a house and got stuck.
              tenant comes outside and mentions her cable just went out.
              when i went to look under the front of the raised house i could see that my cable had come out of a hole in the top of the pipe, and grabbed about 20 feet of cable wire.
              i used a hacksaw to cut some of it and unwound the rest.
              it sucked.
                Here you go Josh.
                I've come close to cutting myself several times when cutting roots/hair off cables.
                Why not make a tool that opens/closes like this
                Get rid of the cutting wheel and add (in the opposite direction) a spring loaded utility blade (replaceable) or two that allow movement of 1". Close it around the cable and pull.
                One size for smaller cable and another for bigger.
                Worth a Seasnake with all the bells???????
                  Box cutter (hair cutter lol)
                  Seattle Drain Service
                    Originally posted by DUNBAR View Post
                    Amen Brother!
                    Meth Freak
                      I like the torch idea
                      I all ways use a pocket knife
                        Box cutter our utility knife what ever finds it's way into my hands first.
                        If I was lasy and let it dry out I just burn it off. Oh smells sooooo nasty.
                        Rod
                        http://unclognh.com
                          mmmmmmmmmmm burtn crotch hair
                          Sent From The StoolBus
                          www.appletondrainandsewer.com
                          Appleton WI, 54915
                          1-920-284-7471
                            Meth Freak
                            Hey it's the first step of recovery! Let the healing begin!
                              I tried to clean my one cable with a torch, I don't know if I held it too long on the cable, but it wrecked the cable. I cut them out now or pull the hair out with my teeth.
