Best Drum Machine?
  • #46
    Re: Best Drum Machine? SPARTAN 1065 !
    You know what they say in the drain cleaning business, miles is miles.
    Maybe Ridgid could have a "Frequent Cleaner Miles" promotion.
    Special K-60 with a counter on it....
    Nah. Rick would tape the handle down and just let it run to win.
    • #47
      Originally posted by appletondrain View Post
      I will second the K7500, also it will only hold 100’ and at times even the 100’ will be hard to put back in
      I'd bet your cable is flipped inside the drum...
      411 Plumb Appliance Stimulus Package
      • #48
        Oddly enough, my new seenake reel seems to be keeping track of it's total usage in terms of feet pushed.
        • #49
          now i know for a fact that i have miles of seesnake use.
          i like to keep the odometer down for resale and power it down when i'm done
          pretty impressive how the footage adds up.
          • #50
            On which model?
            Seattle Drain Service
            • #51
              mine's a mini; the counter is different than my old ones and it seems to be keeping a running tally
              • #52
                counterplus footage counter.
                • #53
                  Back on topic a ' SPARTAN" 300 machine with a
                  second 5/8" x 80' drum and a couple of 100 drums
                  1- 13/32" x 100' and 1- 1/2" x 55'
                  JERRYMAC
                  E-MAILJERRYMAC777@GMAIL.COM
                  FIRE SPRINKLER CONTRACTOR,
                  SINCE JAN. 1989
                  • #54
                    I'm pretty happy with my 300 with the magnum cable.
                    www.ClinkscalesSeptic.com
                    • #55
                      Spartan model 71 with 11/16 cable. Can go through anything with that setup.
                      • #56
                        Don't see many spartan 71 machines the little brother to the 1065, it looks like a 1065 with a 300 drum, and it's lighter than a 1065 too bad they discontinued them.
                        • #57
                          I agree that the spartan 300 machine works well, with the spartan 1065
                          that's a heavy machine with 3/4" incore cable. In the shop we lug the
                          Spartan 1065 with a tommy lift fitted to a tail gate of a pick-up.
                          The risk of back injuries always enters the picture with any employee,
                          sectional drain machines has this advantage over drum machines.
                          In my situation working at a state correctional facility education,
                          and safety are always emphasized.
                          • #58
                            I really like my Spartan 2001. It comes apart fairly easily and the cart will take down the drum and machine separately if there are a lot of stairs involved.
                            The thing is it sounds like a clattering rattle trap when I'm going up and down stairs with the way the cart connects.
                            I like the electric brake and prefer that to letting it coast to a stop. This way the amount of increasing cable tension after removing your foot from the pedal can be minimized. (It's a personal preference thing, and might take some getting used to). It has a 2" smaller diameter drum than the 1065 so it can into a very slightly tighter place.
                            • #59
                              Originally posted by MasterplumberKC View Post
                              I also have a problem with my k7500 and 3/4" cable, it's a pain to get the last 8' or so in the drum, I've had that trouble since day one. It's the only thing I don't like about the machine. Otherwise I like it just fine.
                              I went over to 5/8", but it's just to light for me, and I feel like I'm taking a lot of extra time babying 5/8" on a tough root stoppage.
                              I actually just ordered 11/16" with spartan type ends, which will be delivered tomorrow for my k7500, which I have a feeling will be perfect for the machine, and a few ounces lighter per foot than 3/4", and I know 11/16" will be heavy enough to abuse a little. I'll have to use a 3/4" ridgid pigtail or weld an eyelet up to the 11/16", is the only drawback.
                              I thought about using .66 mag, but I dislike IC cable, and it's expensive.
                              Otherwise I was raised on a spartan 1065 and can't imagine a tougher machine, the problem with spartan is I can't go down town and buy any any part I need for the equipment, rather I have to get it shipped or wait for the rep to call back and then eventually get to me. Ridgid knows there stuff when it comes to distribution and support, that's why I chose a Ridgid this time.
                              was the 3/4" cable IC or hollow?
                              Sent From The StoolBus
                              www.appletondrainandsewer.com
                              Appleton WI, 54915
                              1-920-284-7471
                              • #60
                                nope not at all. 2 new 100' and both will not fit correctly......
                                Appleton WI, 54915
                                1-920-284-7471
