6" line in the basement 8' above ground which machine would be best for that type of
  • 6" line in the basement 8' above ground which machine would be best for that type of
    Hi everbody here,
    kind of new to the trade need some help figuring out difthis one i am in a industrial building the trap is 8' above ground is there any machine you would rocumend above others
    Re: 6" line in the basement 8' above ground which machine would be best for that type
    What machines do you have to work with ?
      where is the clean out? access? if you search there are a bunch of pictures of hook ups to do this. breid.............
        depending on the condition of the line/ stopped up or just maintenance?
        if the line is not backed up, then a jetter could be the easiest as you're not hauling anything big or heavy into the basement. plus the hose will self feed and you're not fighting a cable. this is great as long as you're not stopped up and you don't flood the place.
        assuming the line is plugged up. i've had good luck with my k-60 strapped onto a ladder or the work platform of the little giant.
        but in a true full 6'' stoppage, i would attack it with my 1.25'' sectional cable and timberwolf drill. i let the cable lay in the pipe hangers and it will self feed into the drain. i do this on a project monthly with 6'' pipe.
        of course a drum machine on the floor requires 250# to be rolled downstairs and back up. along with having to run a guide hose from the machine to the 8' mark. it can be done and that's what i used to do on overhead c/o's. now i do it with the jetter, k-60 or timberwolf
          Use a jetter, hire a company that has a large enough one if you do not.
            Originally posted by TRISTATE View Post
            Hi everbody here,
            I'd use whatever machine I had, it's not worth buying a machine for one job.
