Jetter in MD
  • Jetter in MD
    I had one of these thought it was a little small but this is a good price even if used for parts
    http://baltimore.craigslist.org/tls/1526911149.html
    And this in kentucky innercore 3/4" k7500 cable
    http://cincinnati.craigslist.org/tls/1526022905.html
    Seattle Drain Service
    Re: Jetter in MD
    Hey cuda would this size be good for kitchen and laundry drains? Would it be a problem triping a breaker? What about backflow hazards?I'am not too far from Darlington.
      Re: Jetter in MD
      The psi is a little low but I was able to clean some floor drains and sink (grease) lines and some washer lines with it. The price is low but you will need a cheap hose reel, some 1/8 hose and some tips and a foot valve. Just to let you know I ordered the on/off water valve and inlet set up and it was $150 so a hole unit for $200 is a good deal. Plus it was just small enough to run on most common circuits at peoples homes. But with a heavy 10 cord or none at all.
        Re: Jetter in MD
        did you hook the inlet up to a faucet or from a tank? I just found a k-60 old suit case style on there for $800.00 over in elkton.
          Re: Jetter in MD
          I made an adapter to go from kitchen faucet or used a garden hose depending on job. I have bought 2 K-60's new style for under $625 off ebay. Best to buy without cables as I hate paying freight on some guys bent up wasted cables. lol
            Re: Jetter in MD
            Thats like $600 less than most of these stores on the internet. so no worries with crossconection and backpressure backflow?
              Re: Jetter in MD
              These where used units, but I look at the machine for condition of the warning stickers and rubber feat things like that show how it was used.
              As for cross I never worried about it after all the machine sitting outside off the bib is the same thing. And they are pumps. Imagine a guy with a pressure washer out side using the chemical injector and using TSP or worse!
                Re: Jetter in MD
                If it's still there tommorrow.... it's MINE!
                  Re: Jetter in MD
                  well I will have to call him today
                    Re: Jetter in MD
                    The K-60 you are speaking of is one that I am selling. This unit is all but new. The cables, cutters, guide hose are also like new. This machine has been used about 6 times since new. I fully understand Cuda's thoughts on paying shipping on useless cables, but no problem with these. I just don't use this machine enough to warrant keeping it and hauling it around.
