1/8 to 1/4 quick connect
  • 1/8 to 1/4 quick connect
    looking for one. anyone know of a source. this is for a jetter hose.
    the only dumb question is the one that is not asked!
    Re: 1/8 to 1/4 quick connect
    try watercannon.com
    Rod
    http://unclognh.com
      i did. couldn't find one there.
        I may have Jerry rigged mine with a reducer and a nipple have to pull it out and look at it. I think I had this problem too now that I remember.
        have not used my 1/8 x 50 yet but it is set up to work
        Rod
        http://unclognh.com
          i think that is what i'm going to have to do. the nipple thing with a 1/4 qd.
            I pretty sure that is what I did.
            Rod
            http://unclognh.com
              i just got back and bought some reducers. now i just need aqua moles and a warthog and i'm all set!
                as far as i know, there is no 1/8'' quick disconnect made. i use a brass bushing and then a 1/4'' quick disconnect. works perfect as the bushing is pretty much contained within the hose mip.
                do not use a reducer and nipple, unless they're rated for over 3000#.
                a bushing has been fine for years. use brass or stainless. gal will rust and plug your jetter nozzle jets.
                  there is 1/8 disconects but they want $18 for each piece. so yes i'm doing the bushing thing.
