New and Improved Cutter
  • New and Improved Cutter
    This is a great cutter with the spoon attachment to break up grease.
    Re: New and Improved Cutter
    You got me on that one
    Rod
    http://unclognh.com
      I like it!
      www.ClinkscalesSeptic.com
        Gotta be Old Country Buffet...
          Anybody ever get one stuck crossways in a 3" septic hose?
            ron, forget the spoon.
            who else but you and i still have an old school blue seesnake and a spartan auto feed without the cable size adjusting bolts?
            is it just the 2 of us
            i hoped you kept the spoon
            just in case you get hungry
              The front plate on that feed is newer, but the whole feed is about 25 years old.
                Nope it was a high class place that removed the strainer baskets from the indirect drains by the bar. I pulled out 20 pieces of silverware, 3 condiment bowls and tons of broken glass.
                  Glass from traps or lines?!
                    Was all in the 4" p-trap and its riser. These p-traps are 3 feet deep. and the glass, silverware, and other things where filled up the riser pipe about 6" below the floor.
                      I pulled a fork out with EEL cable before. Autofeed? Whats an autofeed? LoL
                      I would be scared to use a retriever like that in any line way too easy to get hung up your a brave man
                        Like all attachments they have a place and time.
                          I run retrievers down lines all the time. I have 4 on my truck just for jobs like this one.
                          I send the retriever down the line pull it out and if its full of stuff like spoons, nuts bolts and so on, I take it off put a fresh one on and send it in. Once all 4 are clogged up I take it to my truck and use a grinder to remove all the retrieved items, then go back in till I no longer bring anything back.
                            Ron u keep that many retrievers on board ? I keep two never needed 4,and fine with it that way. I too still have a spartan old style feeder. Hate the new style. It gets rebuilt and works like new.
                              i have the older non adjustable and newer adjustable feeders.
                              i might drill and tap the older one for a couple zerk fittings to make it easier to grease.
