2500 lb. pressure washer to jetter conversion
  • 2500 lb. pressure washer to jetter conversion
    This $299 kit from Amazing Machinery is Great. I received 100 ft. of 1/4" hose,with hand crank Reel, 5 ft. water feed hose with hand full port valve. lazer 4.5 nozzle,ram nozle,4.5,
    rotating nozzle. so far ,used it on My area drains to street curb. Iplan to use it on My home 1 1/2" and 2" drains. with 1/4" hose plan on either removing house traps or going down vents. Home is 1959 slab on grade, Galvy and C,I. . Thinking this would be a good way to rid soap scum. Think this will be able to make it down bath tub over flow? Shower trap?
    How do You choose on the different nozzles, please. Thanks Tool
    Re: 2500 lb. pressure washer to jetter conversion
    Hey old man! Haven't seen you in awhile here. Merry Christmas and Happy New Year.
    Here's a smilie for you. Click image for larger version
      Here's a smilie for you. [ATTACH]9485[/ATTACH]
      I appreciate that ,Brother. trying to be a little more productive with My time. This site is addictive.
        I forget your P/W specs but it was probably 2500-3000psi 4-5 gpm right? Your set up can do 2" straight lines with a bend or 2 and 3" with the right nozzles, your hose and P/W are perfect for the rootranger! Or get some 1/8" hose and tips and you can do the 1 1/2" lines.
        Buy some tips from Auqua mole he will ask your PW specs and hose length and he drills them for you. Also a good tip for you is the multiball tip for going thru santi's
        Seattle Drain Service
          thanks Cuda .will check out Aqua mole multi mole
