Pics from the STUCK incident
  • Pics from the STUCK incident
    Finally got the pics loaded up from my PITA last week.
    The first one shows the scene of the job (behind the customers garage).
    I was stuck about 30' out and used my sewermatic with 3/4" IC cable and a homemade spear tip (3rd pic pic) to get it loose.
    Last pic is both cables out of the clean out
    After that, got the line clear 150' to city main. Owner's line runs under the neighbor's garage and driveway.
    Re: Pics from the STUCK incident
    Glad you got out
    I'm gonna say this....
    I have never seen a sawtooth cutter that actually had the teeth rounded off to half circles it also looks like the backward swept blades have never been sharpened...
    Could the reason you got stuck be that your cutter was so dull that it could not slice it's way out???
    Sharpen your cutters.
    Bill
      So I have my cable back and the line is clear and spotless confirmed with the seesnake!
      WOO HOO!!
      After clearing the line downstream, I turned my attention to the upstream portion of the line (under THEIR garage) back towards the house and catch basin. Cleared some roots and then hit an obstruction at about 25' and got the camera to inspect. Found about 15' of abandoned 7/8" open wind cable left in the line. My guess is that it was left there from many years ago (before my customer moved in and renovated) and was impitous for the cleanout that I was now rodding from.
      Starting to feel like an episode of the TV show "LOST", but plumbing style. Waiting for the "OTHERS" to leap out with rifles and take me hostage hahaha.
      So I got the retriever out for the old KM-1500 and pulled it back. The cable had obviously been in there for quite a while as the grease and debris had made the cable so brittle it snaps by hand. Took a couple passes, but I got it all out!
      So my customer was happy and appreciative of my effort and I didn't lose any equipment.
      I think that this job may have convinced me that the lines that I deal with regularly are perhaps too !!XTREME!! for the K-60 even with IC cable. 125'-150' of ROSIC (Really Old 6 Inch Clay)
      At the end of the day, the SPEED KLEEN is STILL the Sectional King in my book. But I'm just one plumber with one opinion. I may even be adding a bigger drum to the aresenal just to have some additional options.
      Thanks again for the great tips and advice guys and especially to Ron for offering to come and lend a hand if things got out of hand!
      Thanks to Ridgid for making some great products.
      The last pic shows all of the equipment that I used on this job (not the Ridgid Navitrac case in front) Including:
      KM-1500
      150' 1.25" C-14 cable
      box of cutters
      Seesnake Mini 200' reel with monitor
      Navitrac locator
      General Sewermatic w/th 3/4" IC cable and cutters
      2" PVC leader pipe
      3/8" rod bent into hook for retreiving
      MAPP torch
      100' extension cord
      hand tools
      Not pictured: my most important tool (my brain)
        Glad you got out
        Bill
        I do sharpen after each job, but I may need to give them some extra attention
        The front teeth were sharp when it went in. This line had joints that were pretty rough.
        The clay eats these things up. My 6" cutter that I put in was brand new when I sent it back out the full 150'. When I pulled it back the blade was worn through with almost nothing left.
        Maybe a market for some titanium cutters?!
          Good job gettin that cable out! Don't discount the K-60 it doesn't have to be your only snake that you use just another option for you to use if needed so you can take on anything! Crawl space it's king, roof top it's king! I use it for other things too but it is just one of the many snakes I have to use.
          Seattle Drain Service
            My offer still stands if you ever need a hand on a job, or extra cable for even longer runs ( i have a total of 1200' of 1 1/4 cable) a jetter, K-1000 with around 500' of rods with cutters from 6" to 24" and even a small backhoe perfect for the jobs around town.
            WOO HOO!!
            KM-1500
            box of cutters
            Navitrac locator
            2" PVC leader pipe
            MAPP torch
            100' extension cord
            hand tools
              Holy crap that a lot of equipment!!
              Thanks again!
              Here's the pic on the cover plate of the KM-1500 (Speed Kleen) just for good measure. I need to get a light to go in the outlet on the top too. Anyone remember the one that Kollmann made?
                Thanks again!
                I got one in the garage. One of these days I need to get in there and clean and orginze it. When I do I will take lots of pictures and post them here.
                  Ron, 1,200 feet of 1 1/4 That's long enough to reach my house here in New Hampshire from your clean out at your shop
                  Rod
                  http://unclognh.com
                    Glad it all worked out. Good job
                    Rod
                    http://unclognh.com
                      Thanks again!
                      i certainly do
                      but my advise is to install a heat lamp instead of a head lamp
                        "After clearing the line downstream, I turned my attention to the upstream portion of the line (under THEIR garage) back towards the house and catch basin. Cleared some roots and then hit an obstruction at about 25' and got the camera to inspect. Found about 15' of abandoned 7/8" open wind cable left in the line. My guess is that it was left there from many years ago (before my customer moved in and renovated) and was impitous for the cleanout that I was now rodding from."
                        Congrats on a job VERY WELL DONE. Just the fact that AFTER getting stuck and retrieving your cable downstream, then clearing the 150' of sewer and THEN inspecting everything downstream that you then went UPSTREAM to check things out says a lot about your character and professionalism.
                        But, just for my own education, what does "impitous" mean? I even pulled out my 1934 Webster that is so big it has to be moved by a two-wheeler, and it is not even there. Is it Illinoin?
                          I think he meant "impetuous", kind of like Rick meant "advice".
                          I love my plumber
                          "My Hero"
                          Welcome, Phoebe Jacqueline!
                            I think you mean "impetus", just as you meant "just as", unless you do "kind of like Rick".
                              You think? You're the one that dug out a dictionary. I just guessed. The only way we will know for sure is for Swade Plumbing to tell us what he meant.
                              I love my plumber
                              "My Hero"
