Dual Jetter advice
    Re: Dual Jetter advice
    just reviewing this thread and was amazed that the us jetter i just got has no unloader for the 4000# 18gpm unit. it uses a 3 way ball valve that will either run the jetter hose or divert to the tank. if the jetter nozzle gets clogged, it can blow the burst disc at the pump. basically a machined plastic type disc meant to blow above 4000#
    so now i need to find a dump gun and a dump foot valve.
      18GPM foot valves and guns cost bucks, if you just need it for emergency bypass can't you just use your old stuff? Or are you wanting foot control of the 18gpm jetter? Amazing machinery had the best price on a 20 GPM foot valve.
      Seattle Drain Service
        problem is, it has to be a dump valve. not a shut off foot valve as there is no unloader.
