jetters and maintance
  • jetters and maintance
    Have the power washer jetter conversion.Do You think Using 100 ft of 1/4" hose will be tougher on pump seals , than the washer wand , and larger hose for power washing?
    Re: jetters and maintance
    The nozzle will have more to do with it than the hose. Did the nozzles come with a rate for your washer? What is the flow like. 1/4 should be fine for some smaller washer with the right nozzle. Smaller hose is handy easier to get though bends. Pressure washer hose is 3/8 most of the time but the tips are like 4.0 or 3.0 on smaller washers. Water cannon is a good resource for these sort of odds and ends.
      I like Water Cannon good people
      Rod
      http://unclognh.com
