1/4" jetter line ,and turns
  • 1/4" jetter line ,and turns
    Well I tried to get through a 1 1/2" kitchen sink Sanatee no luck. tried 2 vents 2" and
    I 1/2" No luck. I'm a green horn,what am I doing wrong? House is 1950s Galvy.
    Re: 1/4" jetter line ,and turns
    Call a plumber.
      Call a plumber.
      Call a welder!
        gal pipe means durham fittings durham fittings mean tight turns
        i always had best luck with a spring leader nozzle and a stainless steel hose. plus the foot valve to pulse the hose. a little twisting and turning
        a case of steaks and i'll show you how
          Try putting a coil/loop in the hose that you can use as a handle to twist the hose like rick said Usually works for me.
