Better Cable?
  • Better Cable?
    Can someone settle it. I don't have experience with both.
    Who makes better cable-General or Ridgid? Same size/type of course.
    Thanks.
    Re: Better Cable?
    I can't settle it. I have only used the smaller 1/4" and 5/16" x 25 cables from both companies.I prefer the general. To me its a stiffer cable and lasts longer. The 5/16" is better on roots.
      Re: Better Cable?
      I have used both brands with my K60 (7/8) and my K1500 (1.25) the first year it was only Ridgid cables Second year I mixed in general on the K60 using both at same time I was not able to tell any diffrence in wear.The third year used General on all machines and have not regreted it. I still price the Ridgid products but the local rep seems to be on another planet. So I will keep using General wire. Hope this helps.
        Re: Better Cable?
        I also say general.
          Re: Better Cable?
          I don't know which is better between ridgid and general since I've pretty much only used general cable in smaller machines, and MyTana, or Spartan in main sewer machines. One thing I do know is that general is available at almost every supply house here in the twin cities. I've never seen a ridgid cable at any supply house.
            Re: Better Cable?
            On the k-60 stuff 7/8 and 5/8 I have a mix of both and don't see any difference. I only have general and spartan 3/4" IC and my spartan is better by a long shot.
            Seattle Drain Service
              Re: Better Cable?
              OK, I made this video to show exactly what it takes to break a General 1.25 inner core cable with "L" type connectors.
              I cleaned out my van one spring and took out two cables that had a slight kink. I set them next to a shed and forgot all about them so they spent the summer and part of winter on the ground in the weather, so they were a bit rusty and I was bored.
              I am on snow/ice but this 4X4 plow truck has no problem plowing a foot of snow with out spinning.
              Most of the backing up is actually the tension of the cable pulling me back when I let off the gas.
              I have only used General cable so I can not compare, but I have never had a reason to try anything else.
              Video quality could be better,sorry. Had to do with how I uploaded it. I could change it, but...
              And never mind my Mainer hick accent
              Snaps at 2:38
              http://www.youtube.com/watch?v=WIzK0...layer_embedded
                Re: Better Cable?
                What link do I copy to here to have the video on the post?
                URL or EMBED?
                  Re: Better Cable?
                  Great vid Gene!
                  I have been useing 1-1/4" electric eel cables that are only about 6 months old. I have 5 of them that came apart at the coupling on the female side.
                  I have been thinking about buying general 1-1/4" cables because of the fact i am not happy with the eel ones.
                  Any one else have this problem with the 1-1/4" eel cables??
                    Re: Better Cable?
                    Originally posted by jhplumbing View Post
                    Great vid Gene!
                    I don't get it! When will these companies realize that even the slightest rumor of any cable problems will kill their sales. Of all the equipment I have the very last thing I want breaking is cable. I don't care what the cost is! If they have to raise cost to keep quality then raise the friggin' cost. Be known as the BEST in the industry, not the cheapest.
                      Re: Better Cable?
                      THINKS GENE I ALWAYS WANTED TO KNOW JUST HOW THEY MADE OPEN WOUND
                      CABLES !!!!!
                      JERRYMAC
                      E-MAILJERRYMAC777@GMAIL.COM
                      FIRE SPRINKLER CONTRACTOR,
                      SINCE JAN. 1989
                        Re: Better Cable?
                        CABLES !!!!!
                        Open wound as in winding or open wound as in bleeding?
                        You get close enough to that cable when it snaps and it truly will be open wound cable
                          Re: Better Cable?
                          good job gene
                          i was thinking that if you pulled out the tree or your hitch, that would have been funny
                          next time you have a spare cable, load it up in a 4'' pipe and let edith go at it. i would love to see what it takes as far as torque goes.
                          not sure if i would want to be on the end of edith
                          thanks,
                            Re: Better Cable?
                            Rick, I know you have experience with both. Opinions?
                            Thanks.
                              Re: Better Cable?
                              I have torqued them hard enough with Edith to see a spark come from the cable. I'd like to film it with a high speed camera to see exactly what causes the spark. I'm not sure what it is but it makes an odd snap/jump.
                              I'm pretty sure Edith or my arms would give out before I could break the cable.
