Jetter or ROD ????
    Re: Jetter or ROD ????
    Do most of you carry the larger jetters with you on your trucks or do you need to come back with a trailer or cart jetter?
      I carry a small gas jetter on the truck for grease in kitchen lines (homes) if needed. If I need a bigger jetter I go get my Jettter van. I used to use a trailer with the jetters but it was too big in the city to get into or close to homes. So Thats when I bought a van just for jetting.
      Seattle Drain Service
        I jet 95% of all blockages and I believe jetting does a better job as I have done camera inspections before and after both ways. The only times I feel I need to use my K1500 is when I think the jetter might cause flooding damage or if I need to retrieve the cause of the blockage.
        Recently I was at a blocked sewer for a real estate I work for and I needed to bring back the cause of the blockages as we had been there before and I wanted proof the lady was putting baby whipes down the drain. Well after I removed baby wipes, two pop top drink bottles, a plastic jelly mold,a tap handle, a tennis ball, a large plastic lid and ended up pushing a billiard ball out to the main sewer in street with my camera there was no arguement. Had I used the jetter it would all have just been washed away and I would never had known what had caused the issues.
        So I continue to use both as I see fit.
          I have a 5000psi 5.5gpm jetter fitted to the tray of my truck. I like it that way as it is always with me and is easy to get to the majority of the jobs I attend.
            jet almost everything.
            exceptions are:
            tubs/showers; cable is better for hair.
            some vanity sinks; same reason, some of these get both a cable and a jetter, atypically I tend to jet first and cable afterward if I see indications of hair remaining.
            small galvanized lines; jetter won't make the bends
            flood causing situations where the damage isn't already done
            toilet lines affecting only one or only a few units in multi-unit buildings; they are not frozen if they are inside the building, flooding is an issue, the clog will be close, and slinging hose up the stairwells is a pain.
            some object retrieval/removal scenarios
