2"-4" warthog nozzle
  • 2"-4" warthog nozzle
    Re: 2"-4" warthog nozzle
    i just bought a 1/2'' warthog for 500+
    not sure if a 3gpm warthog will do any good.
    i do know a rootranger will eat the warthog for lunch at those specs.
    don't waste your money on it yet. wait till some of the guys attending the pumper show get all the facts.
      The pumper show?
        I will report back to you on this after the show.
        www.firstresponsedrain.com
          Yep me also
            Me as well, right after the show I tell you a bit more about it.
              I have a 3/8 Warthhog. Its set up for 8 gpm with 300 feet of 3/8 hose. Allen J Coleman. I think that is even too small sometimes for heavy roots. It rocks for grease and has cleared 12 inch line full of manure and bedding. Cant beleve 3 gpm will pull that well.
                For what it will cost.. yeah.. I'll wait for the consensus from the elders. I trust Jake, Ron's opinion.
                  Did you buy a used 1/2" warthog? Or are they on sale somewhere? If you bought it at a business please tell me where.
                  Thanks!
                  Bryce
                  Seattle Drain Service
                      Thanks!
                      Bryce
                      3gpm is the minimum. Thinking this might be the perfect nozzle for 4 gpm jetters when dealing with laterals of less than 150'? I saw a 1/2" warthog on sale on ebay for around 500.
                          I looked at them at the show and talked to one of the reps, the 1/4 wart hog is NOT a controlled spin... so I think it is more of a glorified spinner nozzle, probably work well for removing grease sludgr etc.... but no goosd on roots...Ill stick with my 3/8 warthog it is great fo roots grease or whatever is stuck in the pipe.
                            I have the 3/8 warthog with 5.5gpm and it is good on grease, sludge and even good on baby wipes and some roots at that gpm but I wouldn't go any less gpm eventhough its stamped on it 4-8gpm.
                            Even at 5.5 gpm I think the root ranger reverse turbine is better at cutting roots but the hog is great at actually cleaning the pipes.
                            To be honest I just love having both!
                            Just my opinion though.
                            Phil.
                              I got to try one out before the show. It does not have a controlled spin, but it does have an offset forward jet where other spinners do not. Sadly the engine on my J-3000 decided to not start the day I was going to use it on a known root infested line, so I never got a chance to test it out on roots. I did however use it on a solid ice and tampon blockage, along with a real tight grease blockage. It worked great on them two jobs, it pulled nicely through the line cleared the blockages in one full pass. The machine I used it on as I noted is a J-3000 which is 3000 PSI @ 5 GPM
                              I hope this little review helps.
