Cable Testers Needed - C11 users
  • Cable Testers Needed - C11 users
    Hello Everyone,
    I am looking for cable testers who are using C-11's currently. Please contact me, it will be on a first come first serve basis.
    Thank you for your support
    Renee.Brown@emerson.com
    Renee
    Product Manager
    RIDGID Drain Cleaning
    Re: Cable Testers Needed - C11 users
    Send me 2 and I'll hook em' to the plow truck
      COme on Gene we can't abuse them right away.... Have to stick them in at least one sewer before you attach them to a tree and a truck.
        The cable you should be working on is the 3/4 stuff
          Watch this new C-11 cable is going to be a high tec plastic.
            Dare I suggest a C-11IC?
              I Think Ridgid is try to compete with General and Electric eel with there
              1-1/4" inner core cables
                Ah new cable to play with. A space age high tech. Carbon fiber strands that if they kink you just dump hot water on it and the kinks go away
                Plus only weighs 3 pounds for 200 feet
                To bad that is 100 years away.
                Lets see what you got hope it's good
                Rod
                http://unclognh.com
                  You guys can test something new (and dig it out when it fails) let me know how it works out!
                  Just kidding of course!!!
                    If thats the case I'd like to try them out.
                      When they come out with that, two weeks later 'self healing pipe' will hit the market
                        I'll gladly test 5/8" & 7/8" sectional. All I use thus far.
                          1.25" IC Ridgid cable open wound Ridgid connectors X 15' would be sahweeet!!
                          Looking forward to hearing about what actually is in the works!!
                            you know how to find me!!!!
                            jason @geisel
                              Want an Aussie assessment???
                              Give us a crack at it!
                              Cheers Big Ears.
