Full lead trap
  • Full lead trap
    a new one for me.
    Popped right thru it. Was on the back side of a bath tub. The rest of the pipe was 2” brass
    i have never seen a lead trap?
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: Full lead trap
    that's funny!
    I see them almost every other day. Can't remember the last time I saw all brass waste pipe though $$$ Usually stays lead all the back to the closet bend.
    When I cant see the tub trap and I suspect that it may be lead, I like to use a hand spinner. A simple tub stoppage can turn into a bathroom remodel in a split second
      Re: Full lead trap
      I see a decent amount of these. Especially in the bronx on old standing/barrel waste tubs and stand alone showers.If I know its lead I tell the customer the risks and use a hand spinner and a real soft cable if they want it snaked. Usualy they opt for replacement and the plumber cuts it out and I'll snake it while its open.
        Re: Full lead trap
        I don't see them all that often, but they are out there.
        Have never seen brass drain piping, just brass fittings with copper piping.
          Re: Full lead trap
          Here is one I took out in the summer.
            Re: Full lead trap
            I have cut out a few old lead drum traps,
            Never ran into a lead p trap
            LOL Arkansas hasn't had plumbing that long
              Re: Full lead trap
              Originally posted by delcase View Post
              i have cut out a few old lead drum traps,
              never ran into a lead p trap
              lol arkansas hasn't had plumbing that long
              lmfao
              Appleton WI, 54915
              1-920-284-7471
                Re: Full lead trap
                Removed tons of lead Traps in Boston area. Drum traps, P-traps, pipe. Old classic plumbing. Like seeing pictures of old plumbing a true plumbing skill lost to all plastic.
                Rod
                http://unclognh.com
                  Re: Full lead trap
                  We see lead traps and lead and brass drum traps a lot around here. We melt it down into bars for various things. Here is one i think i may have posted before. Having some fun changing one out. Its for you.........NO its for you.......HAHAHA!!!!
                  www.firstresponsedrain.com
