Like father, like son
  • Like father, like son
    it's been 10 years since this customer has had a mainline stoppage. 4'' non-directional front yard c/o. ran my k-60 with 3'' spiral saw to open the line at 15' in. continued to 30' and pulled back roots and then put in my 1.25'' cable with timberwolf to 40'. first 20' 4'' clay and last 20' was 6'' clay.
    as you can see, the k-60 opened the line, but i then switched to the timberwolf with 1.25'' cable and a 4'' x 6'' spring loaded ridgid cutter modified to fit my cable.
    looks like the old man still has it in him to show the kid how it's done
    looks like we're all eating good. son 7/8'' ridgid innercore, 1.25'' general innercore, and my superbowl boiler.
    the 1.25'' cable with the ridgid 4'' x 6'' expanding cutter modified to fit the general. the 7/8'' ridgid innercore cable with 3'' spiral saw.
    some serious cable with serious roots.
    ridgid 4'' x 6'' cutter with ficus roots for lunch.
    the power of the ficus roots.
    joey, looks like root soup for dinner tonight.
    Re: Like father, like son
    What made you switch to the timberwolf?
    No jetter this time? with your post of jetter pics latley I was figuring that the timberwolf needed a break
      I notice under todays birthdays Timberwolf turns 61.
      So your celebrating the birth of your tools now Rick?
      Your a sick, sick man
        Nice hood to be working in. No payment plan needed.
          the jetter gets used on area drains, and on drains that are so root infested that a cable won't clean. long runs and steep downhills. typically i don't jet sewers unless i have a track record there.
          the k-60 opened the line in a couple minutes pulling back the catch in the photo. but knowing it was a 6'' line to real with, i wanted to install the 4'' x 6'' expanding cutter. i don't think the 7/8'' cable can handle the mass of the cutter. it was designed for the 1500 connector. i even have a 6'' x 8'' expander
            good catch
            problem is timberwolf signed up a year before me and has 0 post
            but now has his own thread
            when is ediths birthday
              So Rick, was the title of this thread a Freudian slip because Joey is pregnant? I am sure whether you guys have a boy or a girl you guys will be great parents. Make sure you teach the baby at a young age how to use a camera so you can finally fire your camera crew.
                I haven't located an expanding cutter. Where do you get yours? and more importantly will a .66 magnum cable handle one? (If you don't think a 7/8" cable can handle it, then... the answer seems obvious.)
                  i doubt the .66 will create enough whip/ rpm to properly hold the cutters open.
                  ridgid makes the cutter, but it was designed for the k-1500 sectional machine. not the 7500 drum machine.
                    Rick do You do Your own modifications ? Do You weld? If so ,Stick, mig tig ?
                    I'm guessing a small Mig . I love fabbing a one of a kind anything.
                      Geno,
                      I have *NO* clue as to the cable you are using but,most around our part of the cold,
                      snowy woods I will run out with double 6"s.They do fine.
                      Had one 8" line ever but no roots...
                      A commercial building downtown with a dip at the clean out!
                      Pull the cap,jump back,go to town!
