If you could buy just one new piece of equipment
  • If you could buy just one new piece of equipment
    my tax lady told me I am getting a refund this year....so i want to put it back into new equipment, so if yo could buy just one thing to help your business what would you buy ?
    Re: If you could buy jost one new peice of equiptment
    still shopping for a decent electric jetter
      It all depends on what you already have and do not have, as well as what you might need another of.
      For me I would there are two things I am looking to get when things pick up for us.
      First is a ProPress rig. I do not do any new construction but for service this thing is a gem. No more waiting to freeze a line or worrying the frozen line will defrost while you are running a torch. Also no more having to drain down a large building. The time and aggravation this tool can save me makes it worth its weight in gold.
      Second thing is either some upgrades to my old trailer jetter, or a new trailer jetter. I am not one of these guys that believe in super high psi with OK flows. I like average psi with real strong flows.
      Now if the funds was large enough I would get into a relining system.
        Need a good residential small commercial jetter this year.
        Rod
        http://unclognh.com
          I have an electric jetter from water cannon 2.2 gpm @1500 psi works good
          only pain is it needs 20 amp I have adapters to plug into 220
          Rod
          http://unclognh.com
            I'd likely buy a camera.
            www.ClinkscalesSeptic.com
              New pumper truck or Vac Con style set up
              Train a part time tech?
              New Jetter trailer 20 gpm 4000 Psi
                Drain cleaning: Micro drain 100' reel and micro explorer
                Plumbing: no question, Pro Press
                And if we're talking bigger bucks...
                A dump truck with trailer hitch and enough hp to tow a trailer with a bobcat or a small backhoe
                Lottery winner:
                A directional boring machine
                  Something like this:
                  www.firstresponsedrain.com
                    Lottery winner:
                    I like that Micro drain 100' reel and micro explorer wish the micro drain was 50 feet.
                    Rod
                    http://unclognh.com
                      Maybe it would be easier for you to tell us what you don't have/or want and we could help from there?
                        Skimming through the new post list I thought this one read "if you could buy josh one new piece of equipment" caught my interest
                          I'm getting lazy. I'd buy a helper. But they're so expensive, and you usually spend more time fixing them than using them.
                            What would Josh want????
                            Rod
                            http://unclognh.com
                              HIRE FOR ATTITUDE, TRAIN FOR SKILL ! Have 4 good attitudes now !
