Going to buy a another P/W to jet with.
  • Going to buy a another P/W to jet with.
    I am going to go get a 5000 psi 4.5gpm P/W. I plan to use this with my 1/4" hose and small rootranger on 3" and 4" lines to completly remove the roots at joints so that a pipe patch can then go in. I already have 10gpm and 18gpm 2500 psi machines for flushing out lines and doing 6" and up but I am never happy on the roots I always still see some left here and there.(damm cameras) My girlfriend is starting to say we need to start a pressure washer company with all the PW's we have.
    Seattle Drain Service
    Re: Going to buy a another P/W to jet with.
    advise MARRY THAT GIRL!
      let us know how that works. high pressure, low volume. i'd be a little worried about blastig out the clay at a cracked joint.
      i've had good luck with my 3000# 5.6 gpm 18hp. jetter with the root ranger and cammera for position and checking it.
        I figure there will be pressure loss plus I can turn it down to 3500 as a starting point, and also use the lower gpm and higher psi for the hydro boring system you made me buy
