Cable spark
  • Cable spark
    I was cabling a sanitary from a toilet line, with the k-60. The floor was damp. I ran 2 cables in, and when i went to snap the third cable together, the cables sparked, alot!! I even got a little shock, just enough to scare me! The machine has a GFCI, i Switched to a different outlet in the house and it worked, no more sparking.
    What causes that electrical spark /shock?
    Re: Cable spark
    improperly wired outlet in most cases. An open ground.
      Re: Cable spark
      LOL the home owner just had his bathroom remodeled.
        Re: Cable spark
        I always carry and use one of these no matter where I am at.
          Re: Cable spark
          i think dunbar is got a video of a sparking drain cleaning job!
            Re: Cable spark
            I'm going to put together a masterpiece with all those clips into one!
            The shame is....the owner of that house died.
              Re: Cable spark
              what happened to him? electricution???
                Re: Cable spark
                Might need to ask an electrician but when you are putting in new code upgraded plugs and you dont have a dedicated ground (3 wire) folks put in GFCI on a 2 wire and tie the ground back to the neutral rather then do the job right...
                Crap, Crap, Crapity Crap!
                Ron(SewerRatz) is right on, A Faultfinder is the only way to CYA and make sure you have a good ground.
                  Re: Cable spark
                  Thanks Ron, I'm going to pick one of these up.
                  On another note, for some reason this photo of you (presumably you) brings to mind a Hobbit. I don't know why that is. You don't look like Frodo at all. Maybe I inhaled too much sewer gas this last week causing synapse misfiring? (just hoping)
                    Re: Cable spark
                    I been told I look like John Goodman when he was in the movie The Big Lebowski
                      Re: Cable spark
                      I get that sometimes too. I went as "Walter" the Goodman character for Halloween last year. Need to find a picture of it. I even had the yellow lens aviator glasses!
                        Re: Cable spark
                        Nah. I'm sticking with the Hobbit. Maybe it's the earth tones in your hat.
                        John Goodman. Loved him in "Brother where art thou" He has quite an acting range if you ask me.
