Dual Drum?
  • Dual Drum?
    Has anyone ever used a dual drum? General makes one and I didn't know if maybe others do and some have used them.
    Just curious of experiences and opinions.
    Thanks.
    Re: Dual Drum?
    Thanks.
    Do you have a link to the duel drum you are talking about?
      Re: Dual Drum?
      Here it's shown as an accessory about half way down on the page to the right.
      I just reread. Small sink cable for this one. Don't know if others are made that can carry larger cable.
      http://www.drainbrain.com/pro/7minirooterxp.html
        Re: Dual Drum?
        Ok thats what I thought you meant. The Spartan 100 you can swap out the one drum for the 13/32 cable to the larger drum that has 1/2" cable in it. The Spartan 300 can also run the 100 drums along with its 5/8 cable drum.
          Re: Dual Drum?
          the micro drain and micro reel can share the same housing
            Re: Dual Drum?
            But the dual drum runs two different cables in one drum at the same time without removing the drum.
            Any advantage to that at all?
              Re: Dual Drum?
              I don't know JC, that seems like a problem waiting to happen. I imagine the cables are separated by an inner drum so what you really have is an oversize small drain machine.
                Re: Dual Drum?
                I will look it over at the show and post better pics and thoughts.
                  Re: Dual Drum?
                  Ron have a good time at the show.
                  Rod
                  http://unclognh.com
                    Re: Dual Drum?
                    Post as many pics and opinions as you can.
                      Re: Dual Drum?
                      And hoist one for those of us who can't make it!
                      www.ClinkscalesSeptic.com
                        Re: Dual Drum?
                        j.c. i own a general mini rooter along with a few other general machines.
                        i would never, ever use it to run a 5/16'' cable.
                        you have a large drum and large style machine running a small diameter sink cable. this is an accident waiting to happen.
                        why drag in a 50# machine to run a 2# cable
                        i'm sure ridgid could make an adapter drum on the 7500 to run a k-39 drum, but how practical would that be
                        running 50' of 5/16'' cable is wrong. name a situation where you need 50' of that small cable?
                          where
                          mobile homes. some mcmansions. k-38 50' x 5/16 www.draincablesdirect.com. breid.........................
                            Re: where
                            Better to have to much cable than not enough.
                            Many times had to go over 40 feet with 1/4 cable. Mcmansions LOL I like that one.
                            Rod
                            http://unclognh.com
                              Re: Dual Drum? You can only hope H.D. and rental co.s
                              Start renting these dueling cables. " Use both cables at once, much faster! "
