Root saw stuck , i'ts monday alright"
  • Root saw stuck , i'ts monday alright"
    My own home, It's root season. soft blockage. General Maxi rooter 3/4" cable 3 " or 4"
    root saw stuck on lower 90 long bend cleanout bottom 2 ' down. Will use pipe tri pod with cumalong . If that doesn't work I'll bring back concrete saw and Jack hammer.
    Re: Root saw stuck , i'ts monday alright"
    tyr a highlift?
    Last edited by appletondrain; 03-01-2010, 12:52 PM. Reason: didnt read the hole thing
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
      If this makes any sense. Hard to explain in writing.
      By hand thrust the cable forward 1' or so give it a 1/2 turn and pull back quickly. Try to do this all in one motion as fast as you can.
      What your trying to do is bounce/move the head around until it lines up perfectly with the opening. It may take a few times until it does.
      If that doesn't work start swearing at it.
        Not familiar with the Maxi rooter. But with my machine If I get stuck like you I can put my Vicegrips on the cable just before the arm inside the drum and run the machine to spin it free. Vicegrips prevent cable in drum from flipping under high torque and pull it free.
        Rod
        http://unclognh.com
          Tool! Try what others have wrote and dump some dishwashing soap in there let it sit a minute, working the cable with the soap in there sometimes is the difference between a kinked cable and a non kinked. I hope this monday thing isn't catching on...I am on my way to real tough job right now.. Good Luck!
          Seattle Drain Service
            I assume you've already pushed it back forward, back and forth several times? Try turning the head so it's oriented differently.
            Do you have a camera you can stick down there to see what's going on?
            If it's only a couple feet maybe you can shove a piece of pipe down to dislodge or move the head?
              Back from shop. Welded 6' tri pod out of
              1 1/2" pipe. No workey, one more pull on cumalong Irishman looses His green teeth.
              Did the dish washing soap right away. Will try the turn n bounce, use to do that when I was Young
                Cut concrete sidewalk, side of our home. Jack hammered small section,removed 18" C.I. RISER above kelly [ 2 way cleanout sweep, RICK HATES ] FITTING. Life is good again.
                Won't use the 4" Rt. Saw next time. I'll use the 3" on My home. Thank's for Your help.
                MURPHYS COOL, KELLY SUCKS, Texas twins from now on IN! You can say " I TOLD YOU SO ,RICK!
                  Nothing goes good when a general contractor thinks he's a plumber.
                    Stop being a SAILOR BOY
                      QUOTE=gear junkie;284086]Nothing goes good when a general contractor thinks he's a plumber.[/QUOTE]
                        Tool, You ran a 4" rootsaw into a 4" Kelly???
                        So the rootsaw hung on the horns inside the Kelly or was it something else?
                          Tool, this one is for you since you said it to me. i guess you not a drain cleaner/plumber?
                          hire a pro next time!!!
                          never put more then a 3.5 in a 4 inch drain. unless there expaders. that move with the spring motion.
                          it can happen to the best of us..... well ok, just you
                          the only dumb question is the one that is not asked!
                            You know what they call a 4" root saw in a 4" line?
                            STUCK!
                            Just one of those lesson we all have to learn.
                              Hey You horses asses It's a general 3 1/2" bend over MARK
