Two way clean-out fitting name ???
  • Two way clean-out fitting name ???
    For the life of me I can't remember the official name of this dastardly fitting.
    Single clean-out opening, but wye's at the bottom w/ a bridge support piece were everything gets stuck creating a backup. I'm sitting here writing an invoice and just can't recollect....it must be Sunday!
    Re: Two way clean-out fitting name ???
    It's known as "Apeeceacrap" Granted, it's a industry slang.
      You mean an Estabrook??
      Rod
      http://unclognh.com
        Apeeceacrap
        That's it!! What a crack up. File under "What things should be called"
          Kelley fitting , COTTAGE FITTING , murphy told me
            Kelly Fitting
              We've always called them "dandy" cleanout tees
                Same as a Texas Twin?
                  no, a texas twin is 2 combies facing each other that are just longer than a single combi. twin risers all in 1 fitting. big price tag, i use to pay $29.00 now they're in the $50's use them for a tight solid fit.
                  if you have the room, 2 combies are less expensive.
                    I always thought it was called a kelley clean out
