Jetter
  • Jetter
    Just starting to learn more about jetters from reading past post on this forum.
    http://www.watercannon.com/pc-549-19...re-washer.aspx
    What size line could this jetter handle? could it handle roots? grease?
    Anybody ever purchase any thing from water cannon?
    Re: Jetter
    go bigger you'll thank me latter
    the only dumb question is the one that is not asked!
      Re: Jetter
      Go longer, you will thank me later too
        Re: Jetter
        March issue of cleaner page 19
          Re: Jetter
          The machine you posted can do a 6" line easily, and if you get a root ranger properly ported for 4000 PSI @ 4 gpm it will tear up roots. A trailer jet will give you more flow. The more flow you get with your PSI the better of a job you can do with fewer passes.
            Re: Jetter
            here's my take on it.
            4000# at 4 gpm is a bit of a stretch.
            rule of thumb for a good gas engine is psi x gpm / 1100 = gas hp.
            4000 x 4 = 16,000
            16,000/ 1,100 = 14.54 h.p.
            i would expect more like 3500psi @ 4gpm.
            remember you need to maintain rpm's to deliver gpm's.
            psi puts a load on the engine, thus decreasing the rpm's.
            i believe robin/subaru makes a 14.5 hp. gas engine.
            honestly, i would rather have a 16 or 18hp with 5.6gpm as a good root cutter for 4'' and 6'' mains. 2'' you can throttle down the rpm's or bypass some water to keep the flow lower. 3'' inside drains can get over filled unless you can go upstream.
            lots to think about with a jetter and water spillage.
              Re: Jetter
              It is Almost overwelming! I have been thinking about building a jetter? after reading other post. My starting jetter budget is about $2500.00
                Re: Jetter
                Interesting... I just had a quick read of their Jetter manual. Page 8 says you can't cut roots with these machines. Not a bad read otherwise. http://www.watercannon.com/pdf/Jette...oubleshoot.pdf
                Sure, jet a Root Ranger properly and it will.
                Whenever I demonstrate a 4000psi 4gpm Jetter beside a 4000psi 5.5gpm the plumber never ever buys the 4gpm unit. We only have one to upsell the 5.5gpm unit or for the plumber with a 5.5 who needs a portable Jetter for high rise work.
                We run 5000psi 5.5gpm on all our trucks with 400' 1/4" hose and 200' of 3/16" hose on the remote mini reel. When we do high rise work we drag the 1/4" hose up the fire stairs then connect it to the mini reel. We found the jet will pull up 10 levels of the waste stack before it runs out of pulling power. (100')
                We also have a 4000/55 DTB 500 Harben and a US Jetter 4018-300 for the bigger jobs. We rarely use them but couldn't be without them! The smaller Jetters do everything else up to 6" and some 9" work with a nozzle extension to stop it turning back on the operator.
                Regards, Bill
                The definition of Insanity: "Doing the same thing over and over expecting a different result."
                Albert Einstein
                  Re: Jetter
                  besides ridgid, who sells root rangers??
                    Re: Jetter
                    Bill does. see post above yours
                      Re: Jetter
                      ar makes a direct drive 5.5/4000 pump, the biggest in the rkv line https://www.pwmall.com/p-135005-4000...rive-pump.aspx
                      direct drive makes a cheaper, easier to build, and more compct machine. if you are going to build your own, that's the way to go. I've had mine up to 4700 psi by accident once; didn't hurt it. usually run around 3000.
                      bigger gives you more options, but eats space and $.
