Drain Cables Direct review. A++++++
    Re: Drain Cables Direct review. A++++++
    One last thing to mention, all RIDGID cables are made out of music wire.
    Thanks
    Renee
    Originally posted by Ace Sewer View Post
    and they have 15% off right now until (I think) 3/28
    Renee
    Product Manager
    RIDGID Drain Cleaning
      Even the 3/4" cables? Can you adress the issues others as well as myself has been having with the Ridgid cables? As you can tell by many posts about Ridgid cables not many of us are happy with the quailty.
      Thanks
      Renee
        ...... crickets....................
          Originally posted by UnClogNH View Post
          I run mine with 1 1/4 eel cable Only. You can really feel the pipe when running the expandable blades. They are very good but can get stuck easy too. They are great cutter.
          1-1/4" That's almost double the .66 I run!! But the .66 does have an inner core. Does the 1-1/4" have an inner cable? I don't even want to think what a couple hundred feet of 1-1/4" would weigh...
          Should I use a bigger cable in the 2001? The thing is I don't normally do that many sewers. Maybe I'll put in the expanding cutter in as a clean up cutter after getting everything possible with my bent leader.
            Thanks
            Renee
            If Your having so many problems maybe your cables made of music wire are out of tune.
            Rod
            http://unclognh.com
              Eel has a 1/2 core. Never used the .66 or 2001 Just wonder if it may give you a hard time. They have it set up on their Model D5 with 3/4 cable. Just be careful
              Rod
              http://unclognh.com
                My model D
                After 8 years is still only on it 2nd cable and going strong
                Eel put out a good cable
                • #23
                  I have said this before, Ridgid used to make a great 3/4" IC cable. about 15 years ago we got our hands on a K-750 and with out its inner drum the cable would flip on itself. When this happened for the first time my father thought for sure the cable was toast. Once we untangled it there where no kinks, or waves. It was one tough cable.
                  We where using it in a few of our machines for years with great success, but within the last year the cable breaks and kinks way to easy. Something has changed. Maybe the quality of the metal being used, the process, but as many here has already posted they are unhappy with the way the cable is performing as of recently.
                  I just hope Ridgid starts making it like they used to.
