gloves
    Re: gloves
    Good 6 mil Ansul Rubber gloves (100 per box for $8 from my welding supply shop) with cheap-o leather palm gloves.
    The good gloves do last but they end up smelling like death long before they wear so I toss them thus the use of cheap gloves
      Re: gloves
      I can't keep track of gloves.
      Most leather gloves do ok and have enough slip to be safe.
      I've also use rubber but you better watch yourself. If they get dry and you get down on the cable it will grab you.
      Little dishwashing liquid on the cable hand helps.
      I'm only talking sectional. I'd be a little worried using rubber gloves with a drum. Probably a rivet mitt or glove and/or leather only.
        Re: gloves
        Originally posted by leak1 View Post
        i use lether gloves from harbor frt., i buy them a dozen at a time. thereabout 1.50 a pair.
        careful with those red and black ones. the dye will bleed when wet and your hands will become black. wear the rubber liners under them
          Re: gloves
          I paid .68 cents per pair of leather palm gloves last week.
          got 50 pair. I have also used the harbor freight ones. Had one rip apart the first time I put it on
            Re: gloves
            How come the Ridgid drum machines come with gloves but the sectionals don't?
            I would think it should be the other way around???
            ... Is this why the drum guys say they are better then the sectionals???
              Re: gloves
              There was a guy at the pumper show selling gloves. I bought a dozen of his Kevlar sewn gloves, used them on a dozen rod jobs and they are still like new, other than the grease on them. http://www.gloves4you.com/catalog_i8...l?catId=323141
                Re: gloves
                RAT----- that is 42.00 per dozen ?
                • #23
                  Re: gloves
                  Yep it is but if the glove outlasts my ugly gloves 3 times longer it well worth it. You can give him a call he will send you a pair as a free sample. Just tell him you want the Tuf-Glove.
                  • #24
                    Re: gloves
                    Thanks for the glove info & links. Ive used welding gloves before with the drum machines, but since I got the steel mits with the k-60, I use those. Just curious why some of you dont like them. either way, I think I'll expand my horizons and try the yellow snake handlers & grappler gloves from draincables direct. they have a quantity discount 15% for 1 or more. if the yellow ones heat up too much, I can always use the right side if the girlfriend gets naughty and needs a little spanky
                    • #25
                      Re: gloves
                      I usually wear latex with leather gloves. Used to wear something similar to the ugly gloves, but it seems that I can't feel the cable as well with the ugly gloves.
                      • #26
                        Re: gloves
                        One white one !
                        • #27
                          Re: gloves
                          I really like the ugly gloves long cuff for the following:
                          (1) Chemical resistant.
                          (2) Safetly grounds a man from electrical hazzard.
                          (3) Blood borne pathages safety, with all the kind of potential
                          diseases, why would you not protect yourself.
                          (4) Latex gloves inserted inside for added protection.
                          (5) Safety glasses protection of eyes, additional porto of entry
                          for unknow diseases.
                          (6) Part of an IIPP (injury illness protection program).
                          (7) Responsibility, complience, communication, hazzardous assement,
                          hazzardous correction, acciddental investigation, education and
                          training, and record keeping.
                          • #28
                            Re: gloves
                            Originally posted by Redwood View Post
                            I guess I'll be different...
                            I never likes wearing wet leather gloves even when the water was clean!
                            latex gloves inside ugly gloves work for me...
                            I wear "C" style with no issues. When noy using your gloves, place a piece of 2" pvc inside so it can air out and not be soaking wet the next time you use it.
                            • #29
                              Re: gloves
                              Originally posted by bdp View Post
                              just looking for some feedback on what type of gloves are preferred. I currently use the pair that came with my k-60 kit, which has steel imbedded in the glove, but I need to get replacements
                              Just from reading all reaplys and info + all the links you guys gave I now know wear to get my gloves thanks all and I didnt even post this Thanks again
                              SMELLS LIKE $$$$$$ TO ME
                              • #30
                                Re: gloves
                                Originally posted by UnClogNH View Post
                                Dan try these grappler golves from draincables direct. I have used Ugly gloves rubber gloves and leather gloves. These work the best and won't get cought in the cables and last a long time.
                                http://www.draincables.com/ProductDe...ductCode=GL104
                                I wonder how these would compare ?
                                http://cgi.ebay.com/Large-Fleece-Lin...item53def6c864
