gloves
  • gloves
    just looking for some feedback on what type of gloves are preferred. I currently use the pair that came with my k-60 kit, which has steel imbedded in the glove, but I need to get replacements
    Re: gloves
    I use welding gloves when running my sewer machine they are thick reasonable and last
    rubber gloves on my small machine
      Re: gloves
      never liked the steel mitts.
      i buy the cheep leather gloves $1.00-1.50 a pair. get a handful of uses then shred them. i wear nitrile liners under them.
      lately i've been wearing the thicker, longer cuff welding gloves and having good results.
      i tend to wear out the left cable glove and not wear out the right.
      anyone want to swap right for left gloves
        Re: gloves
        GLOVES ! GLOVES ? ? ?
        WHO USES GLOVES ?
        BUT REALLY I ALSO PREFER THE WELDER GLOVES WHEN
        I CAN GET THEM THEY ARE VERY GOOD FOR RUNNING
        11/16" AND 3/4" CABLES THEY KEEP THE CABLE SLAP
        AWAY FROM YOUR WRISTS
        BUT I USUALLY JUST USE COMMON WORK GLOVES
        EXCEPT ON 1/4" AND 5/16" CABLE I NEED TO FEEL THE
        CABLE AND WHATS IT DOING
        JERRYMAC
        E-MAILJERRYMAC777@GMAIL.COM
        FIRE SPRINKLER CONTRACTOR,
        SINCE JAN. 1989
          Re: gloves
          I use grappler cloves from drain cablesdirect. Here is a link to their page.
          http://www.draincables.com/ProductDe...ductCode=GL104
          They cost more than normal gloves but last along time and hold up well.
          the chepo gloves for $2 two or $3 bucks will cost more in the long run.
          Two pair have lasted over a year. Where with chepo gloves would have used 20 -30 pairs
          Rod
          http://unclognh.com
            Re: gloves
            I don't have the glove situation dialed in yet. The cheapo leather I can get in xxxl from Grainger so its easy to put on with nitrile gloves but I've had them get caught in the open wound cable twice now. No injury but just a matter of time. Tried the metal embedded mitt that came with the k-60 and I kinda like it, not perfect but not getting wound up in a cable puts me at ease. I need to try the welding gloves. Can buy the left handed mitt only thats a plus.
            wookie
              Re: gloves
              Best pair I ever used someone bought for me at a gas station as joke. They lasted about a year with constant use on my 300.I couldn't find them after that. If I do find em I'll be sure to buy a box and share the make with u guys.
                Re: gloves
                latex examination gloves on first then the leather work gloves in the 3/$10 or 4/$10 packaging. they tend to get too nasty before they get worn out. grease is the ultimate death. i keep a pair in the 7/8 cable stuff buckry and a pair in the 5/8 cable stuff bucket and a spare pair lying loose in case one of the others gets saturated.
                i may get a couple of months if i'm lucky. just part of the cost of doing business
                steve
                  Re: gloves
                  I guess I'll be different...
                  I never likes wearing wet leather gloves even when the water was clean!
                  latex gloves inside ugly gloves work for me...
                  411 Plumb Appliance Stimulus Package
                    Re: gloves
                    The ugly gloves been serving me well for the last couple years as well.
                      Re: gloves
                      That is what I all ways use as well. I have got them caught in the cable once making me twirl and the other just pinching my finger pretty good. I found out it's better to wear them tight as possible for a better feel and to prevent them from getting caught in the cable.
                        Re: gloves
                        Dan try these grappler golves from draincables direct. I have used Ugly gloves rubber gloves and leather gloves. These work the best and won't get cought in the cables and last a long time.
                        Rod
                        http://unclognh.com
                          Re: gloves
                          i tried the yellow ugly gloves for the k-60, but the cable speed is too fast and the gloves heat up too much.
                          i've gone through many cases of the yellow gloves with the 7500.
                          i introduced j.m. mckinney to the yellow gloves and hate to think how many thousands they've sold over the years
                            Re: gloves
                            i use lether gloves from harbor frt., i buy them a dozen at a time. thereabout 1.50 a pair.
                              Re: gloves
                              I use the cheap leather palm gloves also.
                              welding gloves only on root infested lines.
                              Does any one else wash there leather palm gloves? or is this just me being cheap?
